Choke works for long time
Old Oct 16, 2007 | 12:50 AM
Guest
Guest
Posts: n/a
Hi,
I have a 1984 TA with Quadrajet carburetor.
My choke does not "turn off" for minutes after starting the engine.
It started many months ago and it became more frequently during the time.
Now it happens always after cold start. And if I push the gaspedal
for 1-2 seconds totally to the bottom then the choke turnes off.
What could be the reason? Maybe just dirt or something like that?
Thank you,
Laszlo
Old Oct 16, 2007 | 12:07 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Choke works for long time
Is the weather getting colder there? It should take 3-5 minutes for the choke to completely open.
Old Oct 16, 2007 | 01:18 PM
86projectZ's Avatar
Car: 86 Camaro Sport Coupe
Engine: 305 V8 4bbl
Transmission: AT/overdrive
Axle/Gears: stock
yea but what i think hes saying is that it doesnt turn off. i have the same problem. let it warm up, idling at a ridiculous 2000rpm, press gas to floor, or 4500rpm, and it goes normal. An ideas?
Old Oct 16, 2007 | 02:36 PM
Guest
Guest
Posts: n/a
Hi,
Yes, that is what I am saying.
Sometimes it turns off after 1 minute but usually "never".
My idle in P or N is then 2300 and I have to push the gaspedal
to the floor for 1 or 2 seconds and then it turns off.
Otherwise I think it would never turn off.
The RPM does not decrease. It is always 2300 and if I push the
gas then it goes back immediately to 800.
What is this? I thought maybe something is just dirty after 23 years
or something like that and the vibration of the engine help the choke
to turn off.
And the problem is in this status that the brake booster does not really
work because the vacuum is not enough and it is hard to stop the car...
And yes, it is colder now here but this behaviour during winters
was never so bad.
Regards,
Laszlo
Old Oct 16, 2007 | 03:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Try cleaning it on the car with spray carb cleaner first.
Old Oct 16, 2007 | 05:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Choke thermostat getting weak from age perhaps? It's a $25 part around this neck of the woods.
Old Oct 16, 2007 | 06:30 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Once the cars' warmed up,take your air cleaner lid off and see if the choke is fully open.If not,loosen the choke housing and rotate it to the right some until it is.If it is fully open, you might need to adjust your fast idle cam slightly.The small screw on the passenger side just under the choke housing is the one your looking for.Turn it to the left in small increments until it drops down to a base idle.Might take a couple of cold starts to get it to your liking.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
mustangman65_79
Aug 11, 2015 03:17 PM
