what is this for?
Old Nov 12, 2007 | 08:46 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
what is this for?
ok this isnt my car but mines out side and its snowing i havent got it put away yet but anyway whats this tube for th previous owner put on a open air filter and this tube is just there sticking out and its ugly but my question is what is it for exactly and can i remove it safely and how?
Old Nov 12, 2007 | 08:48 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: what is this for?
Looks like the breather neck.
Old Nov 12, 2007 | 08:54 PM
Damon's Avatar
It IS a breather neck. It is part of your PCV system. Clean filtered air is drawn into the motor through that tube, it passes through the motor picking up oil vapor and combustion gasses that get past the rings and then that air is drawn through the PCV valve and finally into the intake manifold via a port on the carb where it is burned along with the rest of the A/F mix.
You can replace it with a breather that plugs directly into the valve cover if you like (for use with an open element air cleaner). The factory uses a tube up to the air cleaner housing so that dirt and water are not easily splashed up and introduced into the motor through an exposed breather.
Old Nov 12, 2007 | 08:57 PM
Brennan's Avatar
so removing it is not an option i take it, so would putting a filter of some sort on it be a good idea or rerouting it so its hidden?.....
i never seen the second parargraph of your post
Old Nov 12, 2007 | 09:01 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
I removed mine when I went to an open element. I just got a breather that mounts to the valve cover. Haven't had any problems.
Old Nov 12, 2007 | 10:49 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
you can get a push in style breather for it. you find them anywhere like autozone, pepboys etc. Only problem is sometimes they can let oil get on the valve cover making them a little black. not a huge deal though. i suggest the chrome ones that have a soil side and the breather underneath. that keeps the slight oil "mist" to a minimum.
