fuel tank sump question
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i am thinking of buyign a sump to be welded in my stock gas tank. how much hp will 3/8 feed and return fittings feed. what size line should i go to after the sump?
thanks
thanks
Transmission: 4L80E/4L80E
If you "need" a sump, you should "need" 1/2" line.
Still running the 305? Doubt you need a sump.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: fuel tank sump question
If you really need a sump I would run -8 lines at least. But I would install a bigger motor WAY before worrying about the fuel lines, that size line for a 305 would be overkill. Factory feed line is 3/8" so sumping it to put those lines on would be pointless as it would be the same size.
Car: 1983 trans am
i the 305 isnt staying much longer and is being swapped for a hot 350 and i plan a little bottle use as well. i will be running an electric fuel pump right off the tank and just thought that this would simplify routingmy fuel lines and look more professional rather than splicing into the factory hard lines and converting to an fittings. would -8 feed and return be adequate for up to 600hp? thats all i need as i am not going to be pushing more than that on spray.
Car: 1984 Z28
what pump you planning on running? Use the pump manufacturers recommendations for line size.
Car: 1983 trans am
i thoguht about geting the jegs billet pump but im open to option scause ive never bought an inline pump before. 110 gph ive been told is what i need.
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
