Help a noob with a carb question please.
Car: 89 Camaro RS
Transmission: Turbo 350
Alright you may have seen my other thread that my fuel pressure gauge reads 0 psi plugged into my afpr, well when i take the fuel line off the carb and plug it, i was able to adjust my fpr to 4.5 psi using the gauge, but when i hook it back to the carb, the gauge never reads any pressure...
is the carb bad? i mean its used and i have no idea how old it is, or am i doing something wrong?
Transmission: 4L80E/4L80E
If your carb was causing this, gasoline would be pouring into the intake manifold.
Has to be something else. Probably something simple that is being overlooked.
84z96L31vortec
Aug 20, 2017 12:16 AM
