CFI to Carb Question
Old Feb 17, 2008 | 12:40 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Heya guys i just bought an 83 camaro with the whole crossfire injection setup wich is acting like complete junk right now.. keeps stallaing on me rondomly ext... anyhows my plan even befor buying the car was to slap an intake and carb on it. i was just wondering if there was a kit for the throttle linkages and tv cable to hook up to an edelbrock 650 or something of that nature. also with the pump only pushing out about 9 PSI will i need a fuel pressure regulator? thnx again!
Old Feb 17, 2008 | 02:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: CFI to Carb Question
There are various bracket setups available that will mount the throttle and TV cable. Most carbs can't tolerate much more than 6 PSI or so, so you'll still need a regulator.
Old Feb 17, 2008 | 04:12 PM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Kk thank! one more question if you dont mind... getting rid of the computer and such will i need an egr enabled intake or non egr?
Old Feb 17, 2008 | 04:40 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You won't need EGR, unless you went through the trouble of putting a non-computer EGR setup on which would probably be more trouble than its worth.
Old Feb 18, 2008 | 10:50 AM
Mirocz87's Avatar
Car: 1988 Formula
Transmission: t-5
Alrighty thanks!
Old Feb 18, 2008 | 11:11 AM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Also remember if you discard the ECM you'll need a non CC distributor(ie with vacuum/mechanical advance).
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
