Burnin Flames
Old Mar 23, 2008 | 08:00 PM
CamAirOh83's Avatar
Burnin Flames
Ok so I have a 650cfm edelbrock carb along with one of those diamond low profile air cleaners. There are times when it's cold outside and I start my car it has a backfire, sometimes causing a fire sometimes not. I think my timing is off a bit. Now I have some questions, what would cause these backfires? Then do the low profile diamond air cleaners happen to catch on fire a lot because of the foam filter? Lets say my timing was adjusted to almost perfect and it still had these backfires, what would I do to stop the backfire.
Then finally I bought an 14-inch dia. 3 inch profile air cleaner to replace the diamond cleaner but it sticks up to high? Is there a hood I could get other then some huge scoop.
Thanks.
Old Mar 23, 2008 | 08:24 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Burnin Flames
If you suspect the timing is off, check it and adjust as needed.
Timing could cause the fires you describe.
Other causes: Bad valve settings, cam phasing, hot spots in the chamber, etc.
Old Mar 23, 2008 | 09:46 PM
CamAirOh83's Avatar
Re: Burnin Flames
What is cam phasing and what do you mean by hotspots in the chamber? Sorry I don't know too much about cars and am only in my second qtr. of my Auto class.
Old Mar 23, 2008 | 11:21 PM
lukn4trbl's Avatar
Car: 2000 SS, M6
Re: Burnin Flames
Cam phasing is a term for the relationship between the valve timing, piston
position and in this case, spark timing as well.
Don't be too concerned with this unless you just completed a cam install.
If the cam is too far retarded, and the timing is not set properly backfiring
can occur.
Hotspots can cause pre-ignition of the fuel mixture while the intake valve is
still open. A hotspot can be caused by an incorrect spark plug heat range,
a burr of metal, or flashing in the chamber, or on the piston crown.
This is also something that you need not worry about unless the engine
was just assembled and the burrs/flashing was not ground down.
Try your luck with the timing first and let us know what you find.
Old Mar 27, 2008 | 03:40 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Burnin Flames
I agree on the timing issue. Get a timing light and check it.
Old Mar 27, 2008 | 07:38 PM
89Creeper's Avatar
Car: 89 Camaro RS
Axle/Gears: Stock
Re: Burnin Flames
I agree with checking timeing first, that would be the most common cause of the backfires. Now for the cleaner you can get a drop plate from a performance shop that will lower your filter about an inch.
Old Mar 30, 2008 | 06:18 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Re: Burnin Flames
2 of my spark plug wires were on the wrong plugs once and it backfired through the carb too (I'm guessing that is what yours is doing) and I fixed them and it was fine. the car also had a major power loss. but this is basically what off timing would do too...
Old Mar 30, 2008 | 07:18 PM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
Re: Burnin Flames
If it only does it when cold, you might check your choke settings. Sounds like it could be a lean condition to me.
db057
Apr 28, 2019 07:45 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
2012sergen11
Oct 13, 2015 07:38 PM
Hello, Michael
Sep 11, 2015 01:10 PM
buckshot63
Sep 10, 2015 09:15 AM
