No Fuel in... floats?
Old May 25, 2008 | 09:31 PM
Nsomnia's Avatar
I worked on my 350 with an edlebrock 1406 and when I tried to start it today there is no fuel.
If i pour gas down the primarys it starts fine. If i pump the throttle gas fumes escape. If i dissconnect the gas line it pumps fuel all over.
I dont have a fuel pressure regulator, is it possibly I blew the floats up?
Old May 26, 2008 | 01:07 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Blow the floats up? I've never heard of that, as the fuel pressure doesn't actually act on the floats themselves, and the typical float failure mode is to flood the carb.
Need more details about your car - year, original induction/fuel system, current fuel system, etc.
Old May 26, 2008 | 01:40 AM
Nsomnia's Avatar
Re: No Fuel in... floats?
I heard that if you ran an electric fuel pump without a FPR you can ruin floats or something.
Its an 87 v6-> 350 swap. Was electric in-tank pump, replaced with mechanical pump. It gets gasoline up through the line, just not into the carb.
Old May 26, 2008 | 01:46 PM
five7kid's Avatar
Did you take out the in-tank electric pump?
What line do you mean it gets gas up to?
Old May 26, 2008 | 09:13 PM
Nsomnia's Avatar
Yes it was running a couple days ago.
The line that goes from the fuel tank to the carb, the gas line/pipe/hose.
Old May 27, 2008 | 12:30 AM
Nsomnia's Avatar
Sucked on the gas line to bring fuel up to the carb and now it ran enough to suck some gas into the floats I guess? SImple fixes are best sometimes.
UNFORTUNATLY, I just picked up a 79 with a 383 for 1700 flippin bucks. I guess its time to say goodbye to the third gen.
Old May 28, 2008 | 08:46 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
If the fuel pressure is too strong, it will push the floats down and flood the
bowls/motor.
The regulator is required to limit the pressure to about 6 PSI for Edelbrocks,
and 7-8 PSI for Holley carbs. There is a needle/seat valve which prevents
additonal fuel from filling the bowl when the float height is reached.
You shuoldn't be sucking on the line to get fuel, the pump will push the
fuel into the carb. You have a dead pump, or severe block in the supply
line (filter? no power?).
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
