Holley 750dp troubles
Car: 1982 Camaro Z-28
Engine: 350 4bbl
Transmission: Borg Warner Super T-10
Axle/Gears: Richmond 10 bolt 4:10 Posi
I have an 82 Z-28 with a built 350 and the 4 speed manual, I played with the carb today(mech secondaries I think) and did get it to idle pretty steady but now it's back to stalling, surging at idle then stalling,bucking like hell at low rpm cruising, and I cant tell if it's backfiring or if it's the massive *** cam the engine builder put in it. Any idea's? Also I'm using mid length headers and a full accel distributor complete with super coil.
Transmission: 4L80E/4L80E
Try going through this https://www.thirdgen.org/forums/carb...ey-tuning.html
If the ignition timing isn't right, nothing much you do with the carb will fix that.
Do you have the cam specs?
Engine: 350 4bbl
Re: Holley 750dp troubles
Yeah it's .632 gross lift and I think he said 312 duration it's a full race cam----------
Oh yeah I cleaned the carb up with some carb and choke cleaner and a tooth brush (venturi's were black and filthy) retarded the timing a few degrees and holy sugar honey ice tea she gets up and hauls, puts ya sideways in second and the burbling is the cam it sounds like a top fueler
Last edited by Bowtiebruiser; Jul 21, 2008 at 08:45 PM. Reason: Automerged Doublepost
Engine: 350 4bbl
Well as Ricky Bobby put it; "I wanna go fast!"
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
