what carb
Old Aug 30, 2008 | 02:06 PM
afida15's Avatar
what carb
i have a 355 with flat tops and un ported 601 heads and a mild cam with .510 lift and a weiand highrise single plane intake. the guy that i got the cam and intake from said the cam and intake should match up nicely. i need to know what carb i should go with. i like q jets but im open to suggestions thanks
Old Aug 30, 2008 | 02:11 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: what carb
what gearing and stall do you have....auto or manual? Q-jet won't fit that manifold without an adapter, edelbrock or holley will fit because of the square flange where as the q jet is spreadbore...maybe a 750 holley or edelbrock w/vacuum secondaries, no double pumpers(engine won't pick up rpm enough with those heads), a 650cfm will give you more throttle response and mileage. but the 750 should be a little more powerfull
Old Aug 30, 2008 | 02:26 PM
afida15's Avatar
Re: what carb
im sorry i left out that info. i have a 5 speed in the car now and for the gearing im about to buy a 02 ss camaro rear end with 3.73 gears for 225 dollars so i can get rid of my 9 bolt with 2.73 or 2.77 gears. and i already have a adapter for that intake for a q jet i just need a new carb cause the one im running it with now is just a old piece of junk q jet
Old Aug 30, 2008 | 02:32 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: what carb
id go with a holley dp maybe a 700 or so http://store.summitracing.com/partde...5&autoview=sku
Old Aug 30, 2008 | 02:38 PM
Engine: L98 494hp
Re: what carb
the engine probably won't have enough power to pick up rpm using a DP, not with stock style heads especially.....go with vacuum secondaries.....
DID YOU SAY 9-BOLT REAR END....that is a rare borg-warner rear end...your better off doing a gear swap into the 9 bolt as it's a bigger ring gear and a lot stronger....double check and count the bolts on the rear end make sure it's a nine bolt...if you do swap for the ss rear end, post that 9-bolt and someone, maybe me, will buy it from you.
Old Aug 31, 2008 | 07:25 PM
afida15's Avatar
Re: what carb
im positive its a 9 bolt, its the 2.77 or 2.73 gearing i know that for sure to, i would put new gears into it but i dont want to spend the money on it and dont want to do it myself. make me a offer for the 9 bolt and il think about it. but i thought that i needed mechanical secondarys since i have a 5 speed. ive been really thinking about a q jet rebuilt from summit.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
