A few carb questions
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
A few questions. First off, how does a Q-jet carb compare to an Edelbrock performer 1406? MPG? How much MPG difference roughly? Power? I've been searching the net but can't find much. I've got a Q-jet already but it leaks gas. I took it to a mechanic to rebuild it and it still leaks. I'm considering just buying an Edelbrock carb rather than trying to find what is wrong with the Q-jet. BTW, the carb will be bolted onto a pretty much stock LG4, (aftermarket exhaust and cold air intake are the only mods so far). Also, are there different carbs for automatic cars vs manual cars? I've found a 1406 on ebay but I'm not sure if there is a feature I should be looking for on the carb for my auto tranny.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: A few carb questions
I'd take the q-jet back to the guy you paid to rebuild it. Unless he did it for free, it's his responcibility, I'd defently do that before shelling out money for a new carb. The q-jet is going to be better on gas with its small primaries and you won't see any noticeable increase in power by just swapping carbs on an otherwise stock setup.
84z96L31vortec
Aug 20, 2017 12:16 AM
