hood fitment???
Old Sep 9, 2008 | 05:22 PM
Jammin'Trey's Avatar
hood fitment???
ok I'm swapping in a 5.7 with 2.02 double hump heads and a performer RPM single plane intake with a holly 750 CFM carb, no spacer and 2 carb gaskets. I was wondering if I will need a special air filter or if it will even fit under my 89 RS hood. Thanks in advance, Trey
Old Sep 9, 2008 | 05:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Just a drop base.
Old Sep 10, 2008 | 11:49 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Re: hood fitment???
Originally Posted by five7kid
Just a drop base.
Im running a RPM Airgap, holley 750 and a 3" filter on a drop base, and it all barily fits under a firebird hood. You should be fine.
Old Sep 10, 2008 | 12:37 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Re: hood fitment???
Performer RPM is a dual plane, not single plane, intake. And I hope those old school heads have had hardened seats installed.
Old Sep 19, 2008 | 08:20 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Re: hood fitment???
Just installed a set of 186 double humps, edlebrock RPM and a holley750 dp and it cleared once I removed the functional hood flap syatem from under the hood with a drop base air cleaner. Its really close though. I had to remove the flaps for the time being so I can see the clearane and it is like 1/4 inch or so from the wingnut.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
