QUESTIONS ABOUT HOLLEY 4 CORNER IDLE
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
If I change the jets in the front plate, Do I need to change to the same in the rear plate?
Also, if I change the PVs in the front plate to a lower number do I need to have the same number in the rear plate?
Carb is a Holley 830 race carb # 0-9381.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: QUESTIONS ABOUT HOLLEY 4 CORNER IDLE
jets have nothing to do with the 4 corner idle. PVs should be the same front and back. I'd suggest reading up on the holley site for tech tips or going to the local library and taking out a holley tuning book, the time spent will be well worth it.
86IROC112
Aug 17, 2015 02:00 PM
