Did I just kill my in tank pump?
Old Nov 23, 2008 | 01:53 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Hi all. I have been jumping the 2 wires on the relay plug for the pump to keep the fuel pump going to run my car, now that it's carbed. I tried to hook a switch to the wires on the plug to manually switch it on and off from inside the car, and when I tried to start it, the light on the switch went out and now the fuel pump will not kick on whether I jump it or not. Is there anything I can check, or did I probably kill the pump? It went from working fine to nothing. No noise, no nothing.
Old Nov 23, 2008 | 02:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What kind of fuel pressure regulator are you using?
Old Nov 23, 2008 | 02:51 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Re: Did I just kill my in tank pump?
I have an aeromotive reg with a return line setup on it. It's the correct one for going from an FI pump to carb.
Old Nov 23, 2008 | 03:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
check the fuse?
Old Nov 23, 2008 | 04:55 PM
Car: 1986 Trans am
Engine: 5.3 LM7
Originally Posted by //<86TA>\\
check the fuse?
There is no fuse. At least not in the fuse box. I went through every fuse in there and they are all fine. I ran a wire from the pump to my battery and it came on so something else is messed up, but I have no clue what.
Also. I DID NOT TOUCH anything on the car, but when I fired it back up, now it wants to stall at idle, and seems like once it gets to higher RPM's it's fine. I pulled a plug and it is pitch black! What the heck could be wrong? Like I said, I havn't touched a single thing since earlier today, and it was running great!?!?!
chazman
Aug 28, 2018 03:25 PM
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Aug 31, 2015 09:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
