Has anyone ever tried this?
Old Jan 3, 2009 | 06:41 PM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
Has anybody ever milled the divider plate in their intake? If so did it help?
Old Jan 3, 2009 | 07:01 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Has anyone ever tried this?
I've known people who have, but they were not happy with the results.
Old Jan 3, 2009 | 07:27 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You could try it if you thought your manifold was choking at high RPM. You'd probably get the same results from an open spacer.
Old Jan 3, 2009 | 07:29 PM
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Thats interesting. A buddy of mine is in the process of building a motor off a set of specs that he acquired from a speed shop and on the specs it says to mill the divider like 3/4" or so to gain a little hp. I thought I would try that to mine, but now I dont know.
Old Jan 3, 2009 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's not a magic improvement that always produces positive results. If you did it on an engine set up for low RPM performance, you could end up hurting it more then helping.
Old Jan 3, 2009 | 07:38 PM
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Say I run a divided spacer and my intake already has a small transfer slot in the divider already and I decide to make it bigger?
Old Jan 3, 2009 | 07:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might make it better, make it worse, or make no difference at all.
