Need Tuning Help
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Need Tuning Help
i have a holley 4 barrel carb List # 9834 1156. im putting in a 350 with a comp cam 256h .447/.454, double roller timing chain, headers full exhaust, edelbrock performer rpm intake manifold im just wondering if anyone could help me out with setting if i screw the screws all the way in on each side how many turns should i do on each screw(turn to left) for this set up to run fine? any help would be appreciated
Transmission: 4L80E/4L80E
Typical is to start 1/2 to 1 turn out, then adjust them evenly for max manifold vacuum at idle in drive.
Car: 1991 Trans Am
Axle/Gears: Stock
Re: Need Tuning Help
ok thanks so do both screws at the same 1/2 to 1 turn out and then put the car in drive put the brake up then work with that also? thanks for you help
Yes, have both screws at the same position within 1/8 turn, both to start and during adjustments.
