Quick fuel line question
Old Feb 8, 2009 | 11:54 AM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Transmission: Th 400 tci super street
Axle/Gears: 3:42 9 Bolt
i have a new mechanical pump for my 383.. the stock pump has 2 inlets. the aftermarket has 1 inlet.. the car has those 2 gas lines. do i join them together into the same line to put them into the one inlet or do i need a different pump?
Old Feb 8, 2009 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Actually, the stock pump has one inlet, one outlet, and one return.
The return style is a little better for stop & go driving, as the fuel isn't as likely to get warm on its way to the engine. The Carter M6626 fits the bill had should supply a pretty healthy engine.
Old Feb 8, 2009 | 02:21 PM
85irocz28's Avatar
Car: 1985 Iroc Z
Engine: 383 carbed
Re: Quick fuel line question
i have a carter pump i forget the part number.. but so wat do i do with the return if it doesnt have one.. ditch it?
Old Feb 8, 2009 | 04:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cap the return line if you're not using it.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
