Holley 650 Throttle Issue
Old Feb 26, 2009 | 04:40 PM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Hey guys I just got my motor running again after my blown head gasket problem, and i came across a small problem with the throttle bracket on my carb. I have the autozone springs that are really strong and worked fine previously until we put this thing back together. Its the one that has a big spring and a smaller spring inside of it. But when you rev up the engine the idle will come back down normally, but it wont COMPLETELY go all the way back. the pedal on the floor is not causing the problem either. It will idle at 1550, and the throttle will go completely back on its own 5 or so seconds later and it will drop to 1100. But i mean its maybe sticking like a few mm's you cant visually see it, but when you put pressure on it with your finger, or pull the pedal the idle will drop. The springs are strong too i have no idea why it would be doing that. I tried putting the springs in a different hole on the bracket but it did nothing. Anybody else experience this with there Holley?
Old Feb 26, 2009 | 07:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Disconnect the throttle cable and see if the problem persists.
Check the carb and mount gaskets to make sure they aren't protruding and causing it to stick. Choke linkage, anything around the carb that could be getting in the way.
Street Lethal
Apr 30, 2019 12:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
