How much hp can you get out of a stock tpi pump
Transmission: t-5
I switched from tpi to carb.
The stock tpi pump is still in the tank and im using the mallory 4309 regulator.
I believe the stock fuel lines are 3/8 feed and a 5/16 return.
My question is what is the possiblities of doing this befor upgrading to a subing the tank or using a fuel cell with a electric pump.?
what is the pump good for?
If the pump is good for some good hp, can i upgrade the lines to a larger size?
What are some numbers ppl have done?
sending me a pm is easier for me if you can.
thanks guys!
thanks guys!
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
Sanjay
Aug 12, 2015 03:41 PM
