Stock LG4 fuel pump(s) for my 350?
Car: '87 Camaro Z28
Engine: fully loaded 350
Transmission: T5-World Class
Hi @ all,
at the moment we are finishing my engine swap an now I have 1 or 2 questions ;-)
In my old car the engine was running with a TBI in tank pump + AFPR without any problems.
My new car is a 87 Z28 and was equipped with the LG4. Now I have read a few threads and learned that the 87 cars have 2 fuel pumps...anyway...my only question is, will the stock LG4 fuel pump(s) support my engine? You can see the specs in my signature.
Greetings,
Simon
Greetings,
Simon
Transmission: 4L80E/4L80E
Shouldn't be a problem if it is all in good condition. The '87 LG4 in-tank electric is a pusher pump in the same league as the TBI pump.
An upgrade to the mechanical is the Carter M6626. A light-weight pump push rod will help it keep up in the higher RPMs.
Your MPH seems pretty high for your ET. Traction issues?
Car: '87 Camaro Z28
Re: Stock LG4 fuel pump(s) for my 350?
Thanks, that sounds good. So the mech. pump is somewhat of an pressure regulator itself!? If I remember right the TBI pump was able to deliver 14psi...
Yes, traction for sure. The suspension is pretty stiff because it is more a road racer...I have once started a thread: "should I have better ET" ;-)
Greetings,
Simon
Greetings,
Simon
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
