hood clearence
Old Apr 21, 2009 | 12:30 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
hood clearence
couldnt really find it in my searches so im just gunna ask
put a 383 stroker in with an edelbrock perfomer rpm and holly 750
im just kinda wonderin what you guys with a set up like mine are doni for air cleaners with a stock hood i really dont want to have to buy a new five hundred doller hood
thnx
zig
Old Apr 21, 2009 | 08:30 AM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
Re: hood clearence
If you buy a drop down breather, you could run a 3" by 14". Looks good and allows plenty of air into your carb.
it'll be a little tight around your distributor but it'll fit!
Old Apr 22, 2009 | 08:02 AM
AKATDOG's Avatar
Car: 84 Z28
Re: hood clearence
thnx
zig
I just bought a K&N 85-3545 works great with an electric choke and clears the hood
Old Apr 22, 2009 | 09:10 AM
Stephen's Avatar
Car: 87 GTA
Re: hood clearence
Both replies are by owners of Camaros.....
Maybe they aren't aware that Firebirds have lower hood lines, so clearance is more of an issue with 'birds than Camaros.....And the OP has a 'bird so......
Old Apr 22, 2009 | 09:19 AM
AKATDOG's Avatar
Car: 84 Z28
Re: hood clearence
true, the one i mentioned has a 7/8 in. drop, if you know how much clearence your looking for would be easier to help, also if you dont have an electric choke there is another one (K&N 85-3549) with 1 1/4 in. drop that might work, also if your using a thick gasket between your carb and intake you can get ones alot thinner...
Old Apr 22, 2009 | 10:45 AM
ziggy89's Avatar
Engine: 383
Re: hood clearence
its a pretty thin gasket between the carb and intake
i had a 2 1/4 in air cleaner and it hit the frame of the hood not just the matting
im thinkin a 2 1/4 withn maybe a 1/2 to 1 inch drop should do the trick but im not positive
Old Apr 22, 2009 | 10:53 AM
AKATDOG's Avatar
Car: 84 Z28
Re: hood clearence
i have a camaro but before i put the drop base on by the time the hood latch was touching the top of the air cleaner was also, mainly at the back of the engine, the 7/8 drop worked great for me
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
