my fuel sistem
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Axle/Gears: 9 inch 3.25/4.11,axles moser 31 spl
Re: my fuel sistem
EDELBROOK no working
my mi fuel sistem bad or good?
any comments
Car: camaro z28 84
Engine: chevy 468
Transmission: th400
Re: my fuel sistem
my " edelbrook fuel pressure regulator " no working (regulator bad)
suggest fuel pressure regulator.
say my mistake?
tank
say my mistake?
tank
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: my fuel sistem
Are you saying that the gauge is not reading 9 psi as stated above, or that the car is not running?
Car: 1987 camaro
Re: my fuel sistem
Sorry man, I'm having a hard time understanding you. If your fuel pressure gauge is reading 15 psi, then you need to dial the regulator down until the gauge reads about 6 psi. From what I'm reading you think the regulator is bad.
is this the regulator that you are using?
http://store.summitracing.com/partde...?part=EDL-1727
make sure it is installed as the directions show.
If that's not it then I would say that you probably have a bad regulator.
Even if its hooked up wrong, chances are that you have a bad regulator. The regulator shouldn't ever put out more than 10 PSI the way read it. Try adjusting the top screw to get 6-7psi at the gauge before you get too upset though.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
