Carb spitting out fuel.
Old May 7, 2009 | 09:47 PM
87GTACamburke's Avatar
Car: 1986 Pontiac Firebird
Engine: 305 4bbl
I have a 86 Firebird. 305. 4bbl. I am almost certain that its spitting gas out,I open'd up my air assembly, and could smell it really strong. I dont know what could cause this,if anyone could give me some help or anything,id appreciate it ,thanks
Old May 7, 2009 | 09:58 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Carb spitting out fuel.
I've seen carbs spit fuel out when they aren't running right, usually timing or something of that sort. Are you sure its not just leaking from the fuel bowl?
Old May 7, 2009 | 10:03 PM
Engine: 305 4bbl
Im not 100% sure,I haven't had the time to look close at it. but thanks.
Old May 7, 2009 | 10:09 PM
Is the car running fine or is it stumbling real bad? If it s running fine check around the front air horn (top plate) screws. Assuming you have the factory Qjet. Sometimes the top gasket starts to leak or the air horn gets warped.
Old May 7, 2009 | 10:19 PM
Engine: 305 4bbl
Im not sure what you mean by stumbling,but lately i have noticed that when i accelerate it does tend to feel like,it doesn't wanna go.Im not sure if that has anything to do with it,It makes somewhat of a low growl sound,then starts to pick up.
Old May 7, 2009 | 10:26 PM
It could be a problem with the carb but I'd check timing too just to be safe. Many "carb" problems end up being distributer or vacuum problems.
Old May 7, 2009 | 10:29 PM
Engine: 305 4bbl
Alright,that helps man,i appreciate it, thank you.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
