Holley Stumble
Old Jun 14, 2009 | 04:59 AM
92RS the beast's Avatar
Holley Stumble
i have a 92 RS with a 400sbc mostly stock. 725 holley on it thats been rebuilt if i punch the gas from idle it stumbles then will pick up. but if i throttle up slow its fine. would that be a incorrectly adjusted accelerator pump.. or is it something else. its drivable like it is.. just irritating if i wanna get on it a lil bit
Old Jun 14, 2009 | 01:12 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: Holley Stumble
when you snap the throttle and look in the barrels of the carb is it spraying correctly? It could be too much carb for the motor......or the accelerator pump is shot and your not getting any fuel at all so when you accelerate slowly the motor doesnt need the extra fuel.
go out and pump the gas and see what its doing.
im guessing carb to big
Old Jun 14, 2009 | 02:09 PM
Re: Holley Stumble
ok, i changed the accelerator pump cam and loosened the spring up some.. and it helped it alot. its alot better. in a few weeks just gonna buy a new edelbrock carb. cuz i got to lookin and it leaks gas from the throttle arm.. and i dont feel like tearin down that baseplate to redo the seals in it
Old Jun 14, 2009 | 04:04 PM
Toyota h8r's Avatar
Car: 1987 Z28
Engine: LG4
Re: Holley Stumble
changing throttle shaft seals is piece of cake
ive went from worn holley to new edelbrock and then traded the edelbrock for a rebuilt holley. i personally loathe the edelbrock carbs.......personal experiences
Old Aug 15, 2009 | 03:21 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Holley Stumble
Which pump cam did you go to? My 350 is doing the same thing. I have a Holley 600cfm VS on it now. I loosened up the pump arm screw and it helped, but its still does it.
Old Aug 17, 2009 | 02:26 PM
fleetmgr's Avatar
Re: Holley Stumble
If you put a bit stiffer spring in your VS you should be able to fix this.
Old Aug 17, 2009 | 02:35 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Holley Stumble
I have the stiffest one(black) in right now. I had a medium one(plain) in before and going to the stiffest one helped, but it still does it.
While I appreciate the answer, I don't want to hijack the thread, I was just looking for a quick answer. I'm having other issues with the carb as well so I think I'm gonna have to break down and start a thread on my issues. Searching isn't working out so well.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
RedLeader289
Sep 23, 2015 06:50 AM
