tpi to carb swap. tcc question
Car: 1989 GTA
Engine: TPI 350
Axle/Gears: stock axle
i am done with my swap. i have one question left. can i leave my ecm in the car and wire it back to the green wire and the tan/blk wire, so the ecm can control the lockup?
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: tpi to carb swap. tcc question
all I did was cut the blk/wht and the tan/blk wires going to the aldl connector and put a switch on it. when the switch is on the tcc will lockup when car is in 2nd 3rd or 4th gear.I only turn mine on when cruising on the highway. I use a trans temp gauge and if it heats up in the city locking up the tcc will cool the trans down.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
