Hesitation and stumbling Holley
Old Aug 17, 2009 | 12:49 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I am running a holley 650 DP on my setup in my sig and am having issues. The carb is brand new with stock jets. The engine ides and runs fine until you get on it. If I give it throttle quickly the engine hesitates and stumbles. Sometimes it stumbles so bad to the point where it almost dies.
I checked the timing and it advances correctly while playing with the throttle. Vacuum is good and there are no leaks . Have a steady 6 psi of fuel pressure and I can see it squirting into the carb just fine. So I am stumped. The only things I could thing of are the carb is too small for this motor, but im pretty sure a 650 is fine for a 350 motor? Also could a mis-adjusted accelerator pump cause this issue? I did mess with this over winter last year when I probably didnt need to.
Old Aug 17, 2009 | 01:05 PM
*86EYEROK*'s Avatar
Car: 1986 IROC-Z
Engine: 420HP ZZ4 350
Transmission: TH350
Axle/Gears: 4:11's
Re: Hesitation and stumbling Holley
I had the same problem awhile back, it turned out to be the accelerator pump needed to be adjusted
Old Aug 17, 2009 | 02:16 PM
fleetmgr's Avatar
I doubt your problem is that the carb is too small. I'd be more inclined to think that it's too big, too soon. I'd especially think that with the gears you have. When you suddenly go to WOT, your port velocity is dropping to about zilch. Get a vacuum secondary carb on that car and your troubles will be over.
Old Aug 18, 2009 | 07:29 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
fleetmgr, it does it while in N and Park also. While we were tuning it we had the same issue. Not just while driving. Whats th eproper procudure for adjusting that screw on the acc. pump?
Old Aug 18, 2009 | 07:40 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Check here. This should get you started.
http://www.holley.com/TechService/Instructions.asp
And here: https://www.thirdgen.org/forums/carb...ey-tuning.html
Old Aug 18, 2009 | 10:00 AM
fleetmgr's Avatar
You can play with different accelerator pump cams and squirter sizes. As long as the screw is throwing the accelerator pump fully, no adjustment is necessary. The cam is what changes how fast the stroke happens.
Old Aug 18, 2009 | 08:51 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
thank you sirs
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
RedLeader289
Sep 23, 2015 06:50 AM
