In tank fuel pump?
Old Aug 21, 2009 | 01:05 PM
paradigmqc's Avatar
In tank fuel pump?
DO a 1987 Camaro carbed have a fuel pump in the gaz tank?
Old Aug 22, 2009 | 09:33 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: In tank fuel pump?
Most likely yes. Check for the fuel pump relay near the booster. You can jump the relay to verify that it still works with the fuel line to mech pump off.
It should also have an oil pressure switch (two wire) in addition to the single wire oil pressure sender for the dash gage.
Old Sep 10, 2009 | 08:08 AM
paradigmqc's Avatar
So it have a fuel pump in the tank and a mecanic one?
because I only get 7psi of fuel pressure.
Old Sep 10, 2009 | 08:09 AM
naf's Avatar
naf
YES and RIGHT
Old Sep 10, 2009 | 08:13 AM
paradigmqc's Avatar
Originally Posted by naf
YES and RIGHT
7 PSI is right?
Old Sep 10, 2009 | 11:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, 7 psi is all you need.
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
