Rich As Hell
Old Sep 13, 2009 | 01:17 AM
Adrenaline91RS's Avatar
Car: 1991 Chevy Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 9-bolt Limited Slip
Rich As Hell
i went and rebuild my 1406 edelbrock carb last night and put it back onto my camaro but now the camaro is running rich as hell and im not sure how to adjust the mixture screws in the front or even if this would fix the problem. Can anybody give me some advice???
Old Sep 13, 2009 | 10:27 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: Rich As Hell
That would be a good place to start. With the motor off, turn the screws all the way in, don't overtighten them. Back them out 2 full turns, that's a good starting point. Get a vacuum gauge, hook it up to manifold vaccum, and start the engine. I usually start with the driver's side screw. Turn it in it little increments and watch the gauge, once you reach the point where you have the most vaccum available before it gets worse if you turn it any more, stop, and give the other screw the same amount of turns.
You'll also have to adjust the idle air screw on the throttle lever, it's a little flathead screw facing the front of the car with the throttle closed. Use the tach to get it at what you want for idle speed, I usually put it at about 800-900 RPMs.
Also when you get it back together, make sure you have the vaccum advance line connected to the right port on the front of the carb. I had to put mine on the passenger side port.
I had the same problem at idle you are describing, turns out my vaccum advance was all over the place when running because I had it hooked up to full vaccum instead of the timed port.
Old Oct 1, 2009 | 11:38 PM
Awesome-X's Avatar
Car: 87 Camaro
Re: Rich As Hell
Should it run with them turned all the way in? Mine doesn't. Is there any other way to adjust them without a vacuum gauge cause I don't have one of those and I'm going on a 150 mile trip tomorrow and I'd like this baby to be pretty good to go
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
Jk_Under
Sep 8, 2015 08:13 AM
