Fuel regulator: Need help!
Old Sep 26, 2009 | 02:16 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Okay, so, I got my holley regulator in the mail (the diaphragm bypass model that will work with the factory FI pump), but one of the few things not covered in this section is...what NPTs do i need to use? it has 3 ports which appear to be 3/8" (or 5/8", cant remember which and I'm away from my bin o parts atm), but I'm at a complete loss as to what adapters I need to use to make it work properly with the factory fuel lines. Also, is there any sort of sealant I need to use to seal the threads?
I've been hunting thru summit and jegs but cant find what I need...maybe I'm just not looking in the right places. Any links or even the correct name/size fitting would be GREATLY appreciated.
This is the regulator I currently have, it apparently will function just as the suggested mallory will. http://www.jegs.com/i/Holley/510/12-803BP/10002/-1
Thanks in advance,
J.
Old Sep 28, 2009 | 12:29 AM
Grumbles's Avatar
Re: Fuel regulator: Need help!
Bump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
