Draining fuel tank
Old Oct 6, 2009 | 10:02 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Draining fuel tank
Hey guys. I was wondering if anyone knew a good way to drain the fuel tank. My 3rd gen has been sitting for 5 years and well...yeah.
I'm thinking getting the fuel out from up front would be the best idea?
Lemme know what you guys think.
Old Oct 7, 2009 | 12:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Some details about your car would be helpful - year, model, engine, induction, modifications, etc.
Old Oct 8, 2009 | 11:02 AM
RocketyMan's Avatar
Re: Draining fuel tank
Yeah..that's true.
It's an '83 305 with the t-5 in it. It's the HO, so it has the carburetor.
Old Oct 8, 2009 | 06:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Get a $5 syphon from the local hardware store and syphon it out from the rear - as I don't think you have an in-tank pump to pump it out with.
Old Oct 9, 2009 | 12:24 AM
RocketyMan's Avatar
I think I'm just gonna take it out from the front of the car and like jack up the back.
Old Oct 9, 2009 | 12:27 AM
RocketyMan's Avatar
Does anyone have a good drawing or pictures of the manual pump on the 305?
Old Oct 9, 2009 | 12:13 PM
five7kid's Avatar
https://www.thirdgen.org/forums/atta...flare_nut2.jpg
#1 is the supply line from the tank, #2 is the return to the tank, #3 is the outlet to the carb.
Problem with trying to siphon these tanks is the filler neck has the opening into the tank facing up - basically the filler tube enters the tank horizontally, the end of the tube is capped off, and the top of the tube is cut open to allow fuel into the tank. Very hard to get a siphon tube to go to the bottom of the tank.
If your car is the HO, it may or may not have an in-tank electric pump (added late in the '83 model year, as I understand). If it does, you can take the supply line off of the mechanical pump, jumper the in-tank electric to run it, and drain it into a container. If it doesn't, you can try to siphon the gas out of the supply line disconnected from the mechanical pump.
Old Oct 9, 2009 | 05:21 PM
RocketyMan's Avatar
Ok wow. So when I went to drain the oil from the engine, I got gasoline/oil mixture. About 7 quarts of it!!! Is there any chance that my manual pump could be leaking into the crank? It basically smells like gas-old gas!!
Old Oct 9, 2009 | 05:39 PM
five7kid's Avatar
A leaking mechanical fuel pump diaphragm is the typical source for gasoline in the oil.
Old Oct 9, 2009 | 06:43 PM
RocketyMan's Avatar
Mk. Yeah I thought so. I'm having a little bit of trouble trying to get the hardline to the carb off the pump but I'm wondering, is there a way to repair the gaskets in the pump?
Old Oct 9, 2009 | 06:57 PM
five7kid's Avatar
It's the diaphragm that does the actual pumping that leaks.
Just replace the pump.
Old Oct 9, 2009 | 06:58 PM
RocketyMan's Avatar
I'm guessing these go out very easily?? And what would you expect to pay for one?
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
