!!! NEED HELP !!!
!!! NEED HELP !!!
ok i have a 91 firebird i did a 305tbi to a 350 carb swap. the 350 was tbi but did a carb swap. i have a brand new edelbrock carb, weiand intake, hei dizzy 4309 mal regulator and comp cam. the timing i think is set correct but it moves back and forth. but when i goto give it gas it stalls itself out anyone have this problem before. what can i do to solve it?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: !!! NEED HELP !!!
Start at 10* BTDC, and adjust from there - seems like a pretty standard place for the carbed 350 folks to start. You'll have to change timing and carb adjustments to get the right mix. With my 350, I had to bump my timing up, and reduce my carb idle down in order to get proper vacuum for the brakes - it's a set, test, reset, retest kinda thing until you get it where YOUR motor is happy.
Car: 1986 Irocz
Axle/Gears: 3.25:1
I don't know what you mean about the timing moving around if you do not even have a timing light ?? I hope you don't mean the distributor moving because it's not bolted down tightly.
Your problem is likely your choke if it is stuck closed. Once the engine is warm, wire your choke so it is wide open. Then you can do your timing adjustment properly and address the choke problem later.
