help with injestion or something
Old Oct 31, 2009 | 08:29 PM
psp963's Avatar
Car: 1989 camaro rs
1989 camaro rs STOCK
(after i fixed the switch thankfully) hey ......i have a problem with my 1989 camaro......So just recently everytime i turn on my camaro it seems very accelerated...... but i had already tuned the carb/fuelinjection to be normal.......it seems accelrated and somehow has a lot of ***** .........but then when i have my foot on the pedal wanting a normal speed ...it feels like i let go of the pedal (gas) for like 2 seconds then SLAMMED on it again.......when the whole time i had my foot down normally trying to have a constant speed. on red light it likr almost wants to turn off
Old Nov 2, 2009 | 05:18 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
Re: help with injestion or something
Do you have a carburetor or fuel injection? These are two very different ways of introducing fuel into the engine and it is impossible to give you advice without knowing what you are working with. If you don't know, take a paicture of the engine comparrtment without the air cleaner assembly on so someone can take a look and tell you what you have.
Never mind, you have injection unless you switched to carb. You may want to try posting in either the TPI section, or the TBI section.
bl85c
Jan 1, 2011 04:35 PM
Jonboy2312
Jan 1, 2009 11:26 PM
Doward
Aug 2, 2004 04:15 AM
92StrokedRS_03
May 12, 2003 02:21 PM
305TBI
Oct 28, 2002 03:56 PM
