Timing question
Old Dec 2, 2009 | 05:11 PM
bcfipp's Avatar
Timing question
What should the timing be on a 305 carb that used to be a tpi setup. Right now it is +2 degrees. Thanks for the help.
Old Dec 2, 2009 | 05:24 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Timing question
i started my carb swap out at 10* advance. i ended up with 12* at idle.
Old Dec 2, 2009 | 05:45 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: Timing question
I'm at 6 degrees, but will bump it up to 8 soon.
Old Dec 2, 2009 | 06:51 PM
bcfipp's Avatar
Re: Timing question
thanks for the info
Old Dec 2, 2009 | 11:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming we're talking about a non-computer carb, initial timing at idle with the vacuum disconnected is typically 8-12 degrees BTDC.
The better way to set the timing is the total mechanical. You need to have either a dial-back timing light or a marked damper to do it because the 34-36 degrees BTDC at the RPMs that produce the max advance w/o the vacuum advance connected is beyond the timing tab.
Old Dec 6, 2009 | 02:41 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Timing question
Yeah 36* total is what I would try, make sure it doesn't ping, I would get an adjustable vacuum canister though or it might ping, I have mine set to 5*, so I have 35* total mechanical + 5* vacuum = 40 total. Hook up the vacuum to full manifold for best performance and fuel economy. Hook it to ported vacuum for lower emissions. My distributor has 22* of advance in it so my base timing is 13*.
Play around with 8-12 base, you need a dial back light to do total timing.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
