Does this sound right about Air and Fuel Mixture?Help Pls!
Old Feb 24, 2010 | 08:31 PM
david_beast's Avatar
Car: 1985 Trans Am
Engine: 350 Small Block
Hey guys,i have an 85 Trans AM with a 350 and it got a holley 600 Carburetor,I can just smell gas going down the road so i decided to adjust the Air and Fuel mixture on the carb,
I came across a site which tells me how to adjust it..Does it sound right??The website is below.
http://www.ehow.com/how_18489_adjust-air-fuel.html
Is there any other way to do it?Sometimes my car wont start after a run,It gets flooded with gas i think,Would putting smaller jets help??Is this process expensive??
Thanks!!
Old Feb 24, 2010 | 08:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Does this sound right about Air and Fuel Mixture?Help Pls!
I wouldn't follow those instructions at all. Idle mixture is best set using a vacuum gauge.
The idle mixture screws, as the name suggests, are only going to adjust the idle mixture. While you're cruising, most of your fuel is coming from the primary main circuit.
Old Feb 24, 2010 | 08:43 PM
Car: 1985 Trans Am
How do i use a vaccum gage?Is a vaccum gage expensive?
Old Feb 24, 2010 | 08:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try this for starters https://www.thirdgen.org/forums/carb...ey-tuning.html
You've also got the advance curve on your distributor set up too?
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
