carb help
carb help
hi i need some help choosing a carb i have a 355 sbc flat top pistons vortec heads 280 magnum cam headers flowmaster exuast and summit intake manifold its in a 1983 camaro with the 700r4 auto trans i was looking a a holley 750 cfm with vac sec and a holley 650 dp i was wondering which one would be better for me or if i should stick with the 600cfm vac sec that i already have and build it up a lil bit thanks
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: carb help
If it were me, I'd save your money and use what you have. You may see a few HP by switching to a 750...but it wouldn't be worth it. You could spend the $500 dollars somewhere else (Wideband O2 sensor, ditch the flowmaster muffler and insert a dynomax, etc.).
Transmission: 4L80E/4L80E
If you have enough stall in the converter to match the cam, a 650 DP would do nicely.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
