can i install a mechanical feul pump on a 89 305
Old Apr 5, 2010 | 07:29 PM
t/a formulas's Avatar
Car: 83 t/a , 89 Formula
Engine: t/a-455 Olds, formula 305
Transmission: soon to be 4 speed, 700r4
Axle/Gears: 2.77, 3.23
the car was TBI , i was wanting to put a mechanical feul pump on it but not sure if i can, is the 4 bolt plate on the passenger side where it would mount and if so, how? all pumps i found only had 2 bolt holes, any help will be great, thanks
Old Apr 5, 2010 | 07:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: can i install a mechanical feul pump on a 89 305
You can - but you'll have to remove the gas tank and take out the in-tank pump and replace with a carb pickup - the mechanical pump will not be able to pull fuel through the unused in-tank pump.
I'm assuming you've swapped to a carb, a mechanical won't produce the fuel pressure needed for any FI.
Why not just get the Mallory 4309 fuel pressure regulator and use the in-tank pump?
Old Apr 5, 2010 | 08:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by t/a formulas
... is the 4 bolt plate on the passenger side where it would mount and if so, how? all pumps i found only had 2 bolt holes, any help will be great, thanks
The factory used a 4-bolt plate with 2 small bolts at the top, and the two fuel pump bolts going in the bottom. You need a different plate, one with an oval hole in the bottom for the fuel pump arm to go through.
Then you need to hope that your cam has a fuel pump lobe on it. And hope that the block has the fuel pump push rod hole drilled.
It would be easier to use a return-style fuel pressure regulator like a Mallory 4309.
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
