Car is running funny; Fuel shoots out of carb
Old Apr 7, 2010 | 08:35 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Today the car shut down. It started up after a few long cranks and when it did white smoke came out the exhaust.
Did it again when i took a turn. So I parked it. Restarted it after a long time cranking. When I was looking at the carb and shook the car, it bogged down than gas shot through the carb.
So I checked the fuel bowl levels and they were fine. Started it back up again and shook it, same thing.
I let it sit at work for 6 hours. Well, I started it and it start up instantly. Opened the hood and there was gas all over the primary bowl so I figure it was from when I started it. Ran fine when I got home, it wasn't warm but it wasn't cold either. When I jerked the wheel back and forth really hard it shut off but when I shook it using my hands it didn't.
Any ideas?
Old Apr 7, 2010 | 10:02 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Car is running funny; Fuel shoots out of carb
did you remove the bowl to check the float level? or did you remove the site plug? make sure the fuel pressure is no more than about 7psi. make sure the float damper spring is not missing.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
