How do I remove my A.I.R. system? 1987 305 QJET
Old Apr 30, 2010 | 01:42 PM
Sprague's Avatar
Car: 1987 Z28
Engine: 305 QJET
Transmission: auto
Axle/Gears: 2.73 non-posi
removing my air system and a/c. lots of lines and stuff for air coming of head near exhaust manifold and just dont know what to remove where and what it will affect. pump was not hooked up anyways. doing timing so i thought it was a good time to clean up engine bay
Old May 1, 2010 | 06:27 AM
Damon's Avatar
Re: How do I remove my A.I.R. system? 1987 305 QJET
Yes, you can remove everything and it won't affect anything except emissions. Remember to plug the fittings where the hoses hook onto the air distribution logs on each exhaust manifold (it can and often does leak, even past the check valves) and the one going down to the cat.
Don't try to unscrew the little individual air tube fittings from the manifolds unless you want to remove the manifolds from the car. They are often just about welded in place from years of rust and hot/cold cycles.
Old May 2, 2010 | 03:48 PM
F41eatsFords's Avatar
I'd give them a shot; mine broke loose easily enough, yours may to. try PB blaster or the like to try and help the process, and if they don't come off with that, THEN I wouldn't bother removing them for the time being. but it's still worth a shot; really cleans the visual aspect of the engine bay up.
Old May 2, 2010 | 05:39 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
What would really help you do this is a set of headers. when i installed mine i removed so much CRAP you could actually see the engine. not to mention the performance i gained over those POS exhaust manifolds.
Old May 2, 2010 | 05:51 PM
RU1NER's Avatar
Hell mine fell of on the driver side, i've been driving with it uattached for probably 6 months now. Sounds weird when it pumps the air.
Old May 3, 2010 | 02:43 AM
Sprague's Avatar
Car: 1987 Z28
Engine: 305 QJET
Transmission: auto
thanks guys ill do that today
backtothe80s
Sep 5, 2015 12:39 AM
beachrodder
Aug 25, 2015 08:05 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
jahblah
Aug 12, 2015 05:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
