Jet sizes?
Old May 12, 2010 | 06:59 PM
Rob 97 Z28's Avatar
Engine: D17A2, L31 based sbc, LS1, LM7
Transmission: 5 spd, built 700r4, T-56, 4L60e
Axle/Gears: 4.11, 3.73, 3.42, 4.56
Jet sizes?
The skinny: getting my holley St. Avenger rebuilt this week and need to know what size jets to run. Just bought a jet kit with sizes ranging from 64-99. Car is a 2 bolt main 350 .040 over, vac. advance/secondaires, 10.5:1 spd pro pistons, comp 365 XFI cam, sportsman II heads weiand intake full exhaust, 700-R4 with 2800 conv. and stock V6 3.23's and a 1 wheel peel diff (until i get that posi outta storage an in the rear-end)
Thanks for the input guys!!!
Old May 13, 2010 | 07:10 AM
Rob 97 Z28's Avatar
Re: Jet sizes?
Nobody??? Buler?
Old May 13, 2010 | 07:42 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: Jet sizes?
If it were me, I would find out what the carb had stock (from Holley) and put those jets in it...and also the same PV and pump cam, shooters, etc. Best to start from stock. You may not need to change much. Get the timing squared away BEFORE you touch the carb settings. I am guessing you will need 16* base and 36* total (all in by 2800RPM). Hopefully you have vacuum advance on the dist. also.
Old May 13, 2010 | 08:11 AM
Damon's Avatar
Re: Jet sizes?
Agreed. Start from stock to get a baseline and tune from there. AND TAKE NOTES! Even the sharpest mind can forget after a few jet, squirter and power valve changes. Add in air bleed changes and you better get an Excel spreadsheet ready.
In the old days people used to write the jet number on the outside of the bowl with a grease pencil so they wouldn't have to remember what the last set of jets they put in it was. Still a valid trick if you make changes only on the weekends when you go racing.
Old May 13, 2010 | 04:26 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Re: Jet sizes?
Boy don't I now know this. Listen to the man! I made up this sheet. Print up 10 or so and write away. Keep 'em right in the car.
Old May 14, 2010 | 06:55 AM
pancherj's Avatar
Car: 1990 IROC
Re: Jet sizes?
Good sheet! I will put it to use tuning in my new 750 Mighty Demon.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
Twinn Engines
Sep 25, 2015 06:27 AM
Twinn Engines
South East Region
Sep 25, 2015 06:25 AM
