3/8" hard fuel line?
Old May 14, 2010 | 06:09 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So.. With an aftermarket fuel pump, with a 3/8" thread on the side.. How do you get to a 3/8" hard line?
The OE pump used basically a transmission line, 3/8" flare. I cannot for the life of me find a fitting that is 3/8" NPT (pipe) male to screw into the pump that will offer me a 3/8" inverted flare female for the line to screw into..??
I have a rubber feed line with a barb into the pump, but like stock, I wanted a hard line up from the pump into the carb. Don't really want to replace the whole thing with braided.
-- Joe
Old May 16, 2010 | 08:49 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: 3/8" hard fuel line?
I have used 3/8" brake lines and cut the ends off, bent them, and used compression fittings with 3/8" NPT pipe thread into whatever connection. Works good. Just tighten the compression fitting snug and you should have no leaks.
Old May 26, 2010 | 06:23 PM
philip052374's Avatar
Car: 91rs
Engine: 6.0
Transmission: 4l60e/3600 vig stall
Axle/Gears: 3.73 9 bolt
here you go
http://www.amazon.com/dp/B0038RAZ52/...2&linkCode=asn
Brass. O.D. tube size x Male pipe. 5 per bag, No. 54348 0606: 3 8'' x 3 8''
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
