new fuel pump.
Old May 23, 2010 | 10:48 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
new fuel pump.
anyone have any ideas for a good high volume mechanical fuel pump?
Old May 23, 2010 | 02:15 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: new fuel pump.
Not sure what "high volume" means. You feeding a dragster or a street engine? But this Carter can probably feed anything you are envisioning.
http://www.summitracing.com/parts/CRT-M6626/
Old May 23, 2010 | 02:32 PM
TNT_Z28's Avatar
Re: new fuel pump.
sorry. i keep forgeting that you have to be crystal clear with your question to get any sort of straight responce out of anyone.
i am removing the intank pump in my 87z and up grading the mechanicl pump on the side of the block. does anyone have any ideas what would be a good one to use? 355ci, xe262 compcam, 650 double pumper.
thank you Phess11 for the suggestion
Old May 23, 2010 | 09:42 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: new fuel pump.
edelbrock performer series or the holley 6 vane, even the carters can supply enough for even a bigblock making above 500HP.
Old May 23, 2010 | 11:01 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: new fuel pump.
Thats because you get a very generic response when you supply a vague description of what your after. Provide details, to get a proper response.
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
