tpi to carb... quick questoin on guages
Old Jun 17, 2010 | 10:51 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
I know ive read it somewere but i cant find it....
Can I use all my stock guages and wiring if I swap to carb from TPI?
Old Jun 17, 2010 | 11:35 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: tpi to carb... quick questoin on guages
yes. just dont cut out the sender wires. i went from tbi to carb and all my gauges work. just leave the ecm in there and remove most of the wiring just going to it.
Old Jun 17, 2010 | 11:55 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
ECM may have to be in place to control speedo on a TPI car - it's a point I've never seen a definite yes/no answer on. You could unplug ECM after your swap and see for yourself if speedo works without it or not. On the TBI cars, there's no need to keep the ECM at all, unless there's a way to retain TC lockup function utilizing it.
Alot of folks take the complete pass side harness out as a whole unit - especially the TPI folks since TPI harnesses are wanted by others. I was TBI - I just left harness intact in my car, tucked it in the fenderwell, and on occasion make use of having cabin-to-underhood in place so I don't have to drill firewall holes.
Old Jun 17, 2010 | 11:57 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
why?
Old Jun 17, 2010 | 03:54 PM
wannafbody's Avatar
Car: 88 GTA
Originally Posted by 86Z
why?
Who are you asking?
Old Jun 17, 2010 | 05:26 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Originally Posted by wannafbody
Who are you asking?
wondering why you would want to switch from TPI to carb...
Old Jun 17, 2010 | 08:41 PM
wannafbody's Avatar
Car: 88 GTA
The motor im getting has a nice carb setup on it.
And stealth ram with fuel rail kit plus tunning sofware and a loptop would be about $1500 +
Thats the only reson really
Old Jun 17, 2010 | 09:11 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Thats the same reason I am going carb, glad you asked the question I was wondering about the speedo too. Looks like we have 1500 reasons to go carb.
Old Jun 18, 2010 | 05:39 AM
wannafbody's Avatar
Car: 88 GTA
yep, if I had the cash i would stay EFI but the stock TPI is probly just gonna go on my truck since thats all its good for.
Old Jun 18, 2010 | 08:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
If its just a rebuilt 350 without much performance upgrade, you can reuse the stock TPI. If its even mildly built, the TPI wont keep up. And as long as you have a cable driven speedo itll be fine. If its electric, youll need the VSS buffer box out of a TBI car for it to work.
Old Jun 20, 2010 | 09:54 AM
smallblockcrazy's Avatar
i have an 89 camaro rs w/ a stock 305 with tpi i was wanting to know what all id have to do to switch to carbureted
lakeffect2
Aug 23, 2015 08:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
happyhapka
Aug 15, 2015 04:42 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 5, 2015 11:02 PM
