Demon for my 355?
Old Jun 25, 2010 | 04:11 AM
Roedster's Avatar
Car: 1989 Formula Firebird
Engine: 355 w/ 750 demon
Transmission: 700r4 / 2000 stall
Demon for my 355?
hey im looking to get a demon carb for my built 355. im looking at 450 to 500 hp.
what carb do you think would give me the best performance in a demon? if you have any other ideas for carbs plez say.
Old Jun 25, 2010 | 06:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Demon for my 355?
Demon goes by you cam specs mostly. Go on there site and look at there selection guide. A decent 350 will use a 650 speed demon. I run a 650 might demon with no complaints.
Old Jun 25, 2010 | 06:29 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
What is the camshaft you are running? I have a Mighty Demon 750 with the annular boosters on my 350. I am making similar power. So far, I really like it. The throttle response and idle are on par with the fuel injection I removed. The overall power seems to be up a little too. I have done very little tuning to it. I had to up the primary squirter to a 37 (was a 31). I also restricted the IFR's a little.
Old Jun 25, 2010 | 04:58 PM
Roedster's Avatar
im running a comp thumper cam, duration 295int/ 313exh, lift .500/.486
summit part #CL12-602-4
Old Jun 26, 2010 | 06:48 AM
EvilCartman's Avatar
Car: '82 Z28
Whatever Demon carb you end up with, before you even get near the car, open the carb up and clean it out. I've had 2 brand new out of the box from years apart that had metal shavings inside. Many others have had the same thing even after claims from BG of taking care of the problem at the factory. With that said, a 750 Mighty Demon would probably work fine on yours and be even better after some fine tuning.
Old Jun 26, 2010 | 08:30 AM
one92rs's Avatar
Car: SOLD!!!!!
get ahold of demon tech support and let them spec you a carb. it is free.
Old Jun 26, 2010 | 04:28 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
And check the 4 bolts that hold on each fuel bowl. I bolted mine on, turned the pump on to check for leaks only to have fuel spray out of both bowls. Called Demon and they said I was supposed to check that. I think for the $500 I spent on the damn thing they could tighten 8 freakin bolts.
Old Jun 27, 2010 | 03:18 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
I have a 750 Demon for sale if you are interested. PM me.
Old Jun 28, 2010 | 04:58 PM
stingray355's Avatar
Is it a Mighty Demon with annular ? How much? Thanks
Old Jun 30, 2010 | 02:03 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
650 Speed Demon VS. If stick I prefer DP.
codeysabatini
Nov 10, 2015 04:07 PM
darwinprice
17
Oct 11, 2015 11:51 PM
mike22115
Sep 28, 2015 04:49 AM
BLK87Z
Sep 18, 2015 11:29 PM
anesthes
Sep 18, 2015 12:34 PM
