Carb size for 327 build?
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
I'm going to be swapping out my v6 for a 327 with 062 vortec heads and a GMPP vortec intake. I want to build the engine with everythign setup so that I can put a blowthrough setup (probably a centrifugal supercharger) later on. Because of that I want to use a holley double pumper so I can modify it down the road to make it compatible with the blow thru setup. Should I get a 650 or 750? How do I size the carb for the engine keeping in mind I will be putting a power addder on later? That might not be for a while so i want to make sure the carb isn't too big for the N/A setup but don't want to have to upgrade when I put the sc on. I'm thinking the engine should make about 300-350hp N/A and then 500-600 with the SC.
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
Re: Carb size for 327 build?
I would assume 750 would be fine until you get your upgrades. I'm not a mechanic though, so don't take my opinion. My engine pushes out 375hp and I have a 650 cfm carb. You might have some issues with a 750 until you get your upgrades but it will still run.
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
Carb CFM = (C.I.D. x Max RPM) / 3456
Multiply your CFM by the Volumetric Efficiency your engine is capable of. For power adders usually 110%.
Axle/Gears: 4.10
I forgot I have a good quadrajet that is currently a spare for my dirt track car. Maybe I'll just go with a quadrajet before the blower and then go for a 750 holley afterwards. Doing the math with the equation:
Carb CFM = [(C.I.D. x Max RPM) / 3456] * VE
Using:
VE = 110% with the blower
Max RPM = 7000
Gives me 728cfm.
Using:
Max RPM = 7000
Gives me 728cfm.
toronto formula
Nov 10, 2015 06:17 AM
Mickeyruder
Sep 2, 2015 02:45 PM
knight72
Aug 10, 2015 09:32 PM
