Bout to switch to carb, is there a direct replacement fuel pump?
Old Aug 1, 2010 | 01:39 AM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
I got an 88 base Camaro with an lo3, and I'm about to swap to a carbbed 383. Is there a direct fit replacement fuel pump I could buy to take care of the fuel pressure needs of the carb or is some sort of a regulator my only option?
PO cut a square in my trunk above my fuel pump so changing it is zero problem.
Thanks for any tips!
Old Aug 1, 2010 | 03:45 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Bout to switch to carb, is there a direct replacement fuel pump?
Just use a mallory 4309. That's what most guys use. Very nice piece. Otherwise you can go to a mechanical pump and make a pickup for it. There used to be a sticky on it... I think. Do a search if there's not.
Otherwise, there are some nice benefits to a switched electric pump. I can check float levels, check for leaks, diagnose a few things here and there without having to fire up the car. I had a problem with primary's floats getting stuck for a little while and flooding the motor, so I could just switch off the pump and run the level down for like 30 seconds and switch it back on and back off etc. Annoying, but it got me where I needed to go til I could take care of it.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
