Choosing a Carb
Car: 85 Trans Am Iroc-Z
Engine: 305 H.O. 4bbl
Transmission: 5 Speed
Axle/Gears: 3:73 Posi-trac
Choosing a Carb
Okay so I have a 305 H.O. 4bbl. I am putting on aftermarket cylinder heads, have the edelbrock intake and am putting in an aftermarket cam, should I keep the stock carb or go with an aftermarket one? If I go with the aftermarket what should I put on?
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: Choosing a Carb
is this gonna be your daily driver or a weekend toy car?
do u want vacuum or mechanical secdondaries?
a lil more specs on the intake cam and heads could help us.
Transmission: 4L80E/4L80E
Without knowing the specifics of the heads, cam, intake, and intended use, we can't make a recommendation.
The only street legal choice is the original carb (which is fine up to about 450 HP, depending upon the engine CID).
Re: Choosing a Carb
okay so right now it has the edelbrock intake, exhaust is done up, planning on putting on Dart Iron Eagle S/S Cylinder Heads and 'Xtreme Energy' Hydraulic Flat Tappet Camshaft
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Choosing a Carb
the stock carb can be made to work quite well for the street, like five7kid said
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
