82 firebird crossfire
Old Oct 10, 2010 | 07:59 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
How hard is it to change a crossfire injected motor over to a carberated motor
Old Oct 10, 2010 | 09:41 AM
Damon's Avatar
Re: 82 firebird crossfire
Not very difficult. Read the tech article about converting over to carb. The basic process applies to all the EFI 3rd gen engines, including CFI.
Carb, carb intake, Mallory 4309 return-style regulator and a non-computer controlled distributor are the main things you need. Not sure if you can use your CFI throttle cable or not, but that's one area that's application-specific. Worst case, you change it out for a different one. Ditto the transmission cable (if equipped with an automatic trans).
Old Oct 10, 2010 | 10:16 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
pretty easy-swapped my car between carb and C/F
a couple times until i had the C/F fully modified to
where i liked...
Basicly a remove and replace operation
A few details:
-C/F throttle cable will work,but is best switched to
carb as it is long
-tranny cable is the same
-for the fuel pump,can use the original with a regulator
and modified wiring,or just leave original pump in place
and install a mechanical pump as since the original is
a turbine type,fuel can pull through it easy with it
inactive-unlike a roller or gear type pump.
-a circuit will need to be rigged for the TCC clutch
in the tranny(unless tranny swapped for non TCC)
jtwoods4
Sep 3, 2015 05:39 PM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
3rdgenparts
Aug 6, 2015 09:03 AM
