Stuck...how does one remove the screws on the metering block? (pics inside)
Old Jan 14, 2011 | 09:53 PM
bsn1989's Avatar
Car: 1984 Firebird
Engine: 388 CI, Lunati Cam, Ported Heads
Transmission: 700r4 Pro-Built
Axle/Gears: 3.23 10 Bolt with mini spool
Hey all,
I am gonna start my 4160 rebuild. I need to remove the metering block but the screws that hold it in have a weird head. I read somewhere that they are clutch head screws and that I need a 5/32" clutch head bit/screwdriver to get them out. Can anyone confirm this?
Thanks!
BN
Attached Thumbnails Stuck...how does one remove the screws on the metering block? (pics inside)-dsci0806.jpg
Old Jan 14, 2011 | 09:57 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Stuck...how does one remove the screws on the metering block? (pics inside)
I don't know, but that looks like it takes a special tool. But I would take an old POS screwdriver and make a tool out of it.
Old Jan 15, 2011 | 03:33 PM
No need to make anything. THat's a quite common screw drive actually. Very easy to get the right tool for; there's only about 2 or 3 sizes of them, kind of like Phillips.
Its name is "clutch bit".
http://www.sears.com/shc/s/search_10...it&vName=Tools for example
Old Jan 16, 2011 | 03:08 PM
bsn1989's Avatar
Car: 1984 Firebird
Thanks Sofa! You wouldn't happen to know the exact size of them of hand would you? Thanks!
Old Jan 16, 2011 | 07:35 PM
Damon's Avatar
Don't know. I have the right one but no markings on it.
A regular screwdriver of the appropriate blade size will get them out. That's what I used to use before I got the right tool.
Old Jan 17, 2011 | 07:35 AM
As you can see they are DIRT CHEEEEP.
At less than $1 a bit, buy all 3.
Some things are not worth being "penny wise and pound foolish" over.
Old Jan 18, 2011 | 09:35 PM
bsn1989's Avatar
Car: 1984 Firebird
Thanks guys! Also found a link on a Holley forum that confirms my suspicions. That it is indeed 5/32.
http://www.holley.com/forums/showthr...Tools-Required
Old Jan 30, 2011 | 05:59 PM
bsn1989's Avatar
Car: 1984 Firebird
Just an update guys, the 5/32 clutch head bit was a PERFECT fit! Thanks again for all the help!
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
Mar 10, 2016 10:35 PM
camaro71633
Sep 1, 2015 10:24 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
