carburetor
Old Mar 9, 2011 | 07:57 PM
Guest
Guest
Posts: n/a
carburetor
need help on how to adjust a 750 Edelbrock it floods and back fires or do you think timing might be off
Old Mar 9, 2011 | 10:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Yes, make sure the timing is correct. Did it just start doing this? Did you just install the carb? What distributor do you have?
In case it is the carb, the stickies already have you covered:
https://www.thirdgen.org/forums/carb...e-rebuild.html
Old Mar 10, 2011 | 10:28 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: carburetor
Need to know:
1) Motor size?
2) What distributor?
3) What fuel pressure regulator?
4) What fuel pump?
5) What tranny?
6) What is base timing at?
85cmroz28
Oct 4, 2015 09:44 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
