Not sure of what fuel pump I should use?
Old Mar 26, 2011 | 08:27 AM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
Transmission: POWERGLIDE
Axle/Gears: MOSER 12 BOLT 5.36 1/8 MILE ONLY
I am currently runing a 350 (385hp) with CC Q jet. I have an issue with car nosing over at high RPMs. I have Carter mechanical pump and want to add an electric in in tank. Would like to know wich will work best TBI pump or pump from L69. Also how much presure do these pumps put out.
Thanks Frank
Old Mar 26, 2011 | 08:37 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Not sure of what fuel pump I should use?
TBI pumps 12 psi. TPI pumps 40+ psi. Keep in mind, it's not the pressure only, it's the flow rate - folks say a TBI pump doesn't flow enough. But there are higherflowing TBI pumps available.
What year car? If it's 1986 or 1987, chances are you already have a "helper" pump in the tank.
I'm not convinced your issue is fuel - cars with way more hp than yours have been using mechanical pumps for years and years.
What's your total timing at 3000 rpms? What's you initial timing? Might need more timing advance to 'come in' quicker for your motor.
Old Mar 26, 2011 | 09:18 PM
FJA1791's Avatar
Car: 1990 IROC-Z
Engine: 355/AFR 210
My car is an 86 and did not come with helper pump. My total timing is 32 and initial is 10. I really feel that its a fuel issue....if I were running a Holley I don't think this problem would exist.
Old Mar 26, 2011 | 10:00 PM
Car: 1992 RS
Engine: Carbed 350
I forgot this is computer controlled carb - it's taking care of timing for you (I'd guess). Old man having a brain fart here - my post is totally not helpful, sorry.
Might try just a regular external electric pump back at the tank to help, like a Holley blue or something. I'm certainly no expert with the CC carbs.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
