detent cable help
Old Mar 26, 2011 | 07:34 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
detent cable help
I need some pics of the drivers side of a non cc qjet. The po of my car put a 327 in it and the detent cable was just holding on with a piece of wire. I bought the clip to put on end to try and fix, but I don't know which area on bracket goes. Where it works , the cable goes at an angle I am not comfortable with. So picks of the throttle cable , detent cable would be nice as weel as the bracketry, for I believe mine to be wrong.
Old Mar 27, 2011 | 01:25 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: detent cable help
Anyone?
Old Mar 27, 2011 | 12:27 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You need a TV cable geometry corrector, specific to the carb, about $20 at Summit. And good sturdy throttle cable bracket to hold the TV cable and throttle cables. Sorry, no pics today, it's raining.
BUT ... DO NOT DRIVE this car without this getting fixed, you'll burn up the tranny if you haven't already!
Old Mar 27, 2011 | 12:36 PM
Awesome-X's Avatar
Car: 87 Camaro
Yep i just burned out my D and OD because it was slipping into those gears and I said eh, I'll fix it tomorrow.
Where did you get the end clip? I need one as well.
Old Mar 27, 2011 | 12:43 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I don't drive. I want to, which is why I need to fix. I am assuming the braket that is on it now if for a truck, because that is what carb is off of, but I am not sure. A also don't know how long it was driven like it is now. So the bracket should be specific to carb and vehicle, not engine or intake? So I should be able to pick up a bracket for any thied gen with a carb, cc or not??Clip I got at oriellys, dorman part number 41020 I think.
Old Mar 27, 2011 | 04:20 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
I may have right brackets, just not hooked up right, so if anybody has pic of how it is supposed to be hooked up, I would appreciate it
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
